Cascade Designs Build
terra
Box is 10 cu ft tuned to 34hz for 2 Cascade Designs Omega 18"s. Power will be from a Memphis 4kw powered by 2 kinetik 2400's in the back and a 250amp alt. The front baffle is bolted to the box so that if I want to burp, I can switch the port baffle out with one of a higher tuning. Pretty **** solid box.
You must get pics of the moofers ASAP. Do you own/work for Cascade Designs?
Prototype should arrive next week I hope. I'll have pics up asap. Production run should follow soon after.
I figured. Got any specs of the sub?
nothing has been finalized but..
8 layer flatwound aluminum coil, kevlar reinforced cone, triple slug motor, 6 spoke baskets...power handling will be rated at probably 2k but they'll take upwards of 4k daily.
Why would that post be in this thread //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
But I cannot wait to see the finished build
terra
terra
Yes
scarolinablazin
Mike Mccabe
