I haven't the luxury of driving a car immediately preceeding and following an HO alternator installation to compare performance and effiicency.
However, let's compare something that is similar with this respect, as it's a drag on the engine -
Consider turning on your A/C. While the A/C pulley is always spinning, when engaged the compressor puts additional drag on your motor, and you can feel that - and it does make a noticable dent in accelleration and passing power.
I've noticed that with cars small to large...
- I have a 1.6l Honda Civic that's got some performance goodies. Noticed it both before and after installing a supercharger on the car, 125hp before, 195hp after, noticable both before and after.
- My wife has a 2.0l VW new beetle, very noticable on her car, particularly being an automatic.
- I have a Nissan Pathfinder, 3.0l V6. Noticable again, even being a 5 speed (automatic is against my religion).
- My best friend has a Z28 Camaro, 5.7l V8, show car, modified with performance goodies. Noticable on that car also, again his being an automatic, you can tell particularly in throttle response and shift point differences.
This is just a pure statement regarding the drag on a motor.
The additional drag on the motor related to the alternator should be relatively easy to predict, simply due to the law of conservation... it should be proportional to the difference in current, between your new alternator and old one (assuming similar efficiencies, of course. Not too many variables in alternator technology relating to that really).
That's personal opinon - not factual documentation. It's pretty much impossible to turn around and go "my subwoofer is inefficient, there... fixed." The listening habits of people vary quite drastically. Your idea of adequate, is NOT someone elses.
If you have a 12" subwoofer stuffed into a 1/2 cu.ft. box... sure, that sub might soak up 1200 watts without coming close to it's excursion (or output) capabilities.
But if you put that same sub in a larger enclosure, possibly ported... you might get not only the desired increases in output, but you might reach that with only 400 watts even.
That's the point.
If you have a system that's soaking up the power of a Viper 2500D, sending your electrical system to it's knees, but you aren't satisfied with the results, there are probably gains to be had by revisiting the enclosure design.
Installing an alternator would be a band-aid, masking the true problem, which would be an inefficient enclosure design.
The enclosure drives efficiency orders of magnitude greater than the internal efficiency of the subwoofer itself.
And Hoffman's Iron Law defines what you can trade off to gain efficiency, in designing that enclosure.
...popped 100 bucks out to install something that is a half-assed attempt at a repair. Not a primary supply device, it's just a storage unit.
Exactly!
It's not a primary supply device.
It's installed to
augment, to help your electrical system respond to this nasty thing hanging off your electrical system (ahem.. the amplifier) that's trying to demand current faster than your electrical system can deliver it.
