cap question, please help
SuckMikeHawk23
#1 Laker Hater
is it possible to fry my cap? i just bought a cap today and was going to charge it, instructions said to hook up the positive first, so i did, then it said to hook up the negative to some kind of resistor or a bulb, then to the ground.... well, since it didnt come with the resistor or the bulb, i just hooked it straight up to the ground, then it started sparking... now when i touch the negative to the ground terminal on my battery, it wont spark no more... ok, with that said, how the hell do i kno if my cap is even working or not? theres no light on it, or at least i dont see one, and its not digital, so how do i even kno its going?
thanks
I have personally seen caps make very violent reactions when shorted out. My electronics teacher actually fused a screwdrive to a fully charged cap the size of a 44oz cup at 7-11. This was all in the name of safety of course. He didn't want us to kill ourselves. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif Anyway, I know the resistor is used so that the cap doesn't **** all the juice from your battery. The only way I can think of testing it would be to use a DMM.
thanks for the info, anyways, im still doing the install and i accidently touched the pos and neg wire of the cap right now and it sparked like hell (duhh!!!)... anyways, i guess theres still some kind of resistance, current, or power in the thing, any other way to test if its working besides taht?
A DMM will work for measuring the current, voltage, and resistance. DMMs cost anywhere from 10 bucks to 4-figure numbers, and I wouldn't buy anything less than $50. It's a good investment if you ever plan to do anything with electronics in the future.
The only thing I would be concerned with is you might have shortened the cap's life by shorting it and it may not have the same storage capacity was it once did.
it shouldn't have hurt it too much it would have just charged it very fast. the reason it wouldn't spark the second time is probably cause it was fully charged not cause it was ruined. you should be able to tell it's working when it's hooked up if your sub gives longer stronger low notes. you could always throw another $20-$50 and buy the digital monitor for the top of your cap.
well, everything is running right now, but i havent had time to test the cap with a test light, is there any other approach i can take to assure that my cap is working properly?
my bass notes seem to be hitting at the same level as before, and my lights are still dimming, im just hoping that my alternator is too weak and that my cap is fine... any thoughts?
thanks
well for the time it will take you to write another reply on here why don't ya run down to a local service station and ask a mechanic to use his multimeter for a second. set the multimeter to 20v or whatever and see what the cap is holding
i think caps make a difference. they allow your amp to give longer fuller low's..... in my friends car when he first hooked his system up his lights would dim with the music like right down to nothing and he added a 2 farad cap and it fixed everything..... they do put more strain on your alternator though. don't use them for a backup if your alternator or rest of the charging system is lazy. i think they probably give you more output from your amps if the rest of the charging system is healthy. instead of your amp getting like 13v spike from the battery it can get (depends on the cap) like a 20 volt spike or more. ( more voltage going in = more wattage coming out i'm assuming)
yall. I unplugged the radio harness and the antenna and plugged it all back in and it works. I guess its fixed… suppose it was the head unit...
873
You fell for the capacitor meme. Throw that **** away.
899
LOL - mine was a higher end model too - iirc deh-9300. Low mileage too, it was sitting around for year collecting dust.
7
416
One or two, they are still subwoofer outs and are mono summed signals from both left and right. Even the 2 RCA subwoofer pre-outs on the 2nd one...
770
SuckMikeHawk23
#1 Laker Hater
SuckMikeHawk23
626 California
Fuel37
Decebal
    Jun 10, 2024
Decebal
    Jun 10, 2024
