Can't play video on Pioneer 3300BT
ace_800
Ok, so i thought it was because I wasn't running the video in divx format, however I can't even get a standard dvd to work. I get sound but no video. I thought maybe I switched a wire on the bypass that I did, but its correct. The only wires I don't have hooked up from the pioneer is the violet/white for reverse and the yellow/black for mute. I doubt either would cause a dvd not to play though. I have the metra GMOS LAN 012 to keep onstar and everything, however my vehicle isn't factory amped, it was the standard. That shouldn't affect the HU either since I still get everything to work as it should except the video.
Anyone have any thoughts?
Does a standard DVD work? There's a resolution limit that Pioneers have, or it could be an issue with the particular codec.
standard doesn't work
Did u ground the wire that says parking brake? If u didn't, do it
No, I have the bypass with the 12v relay. It's grounded in the relay setup. I don't get the video error.
Light green wire..
hooked to the 86/30 of relay for ground, 85 to the remote wireless, 87 to the parking brake
If I recall correctly, if the parking brake wire sees a constant ground, it will not show a warning, just a black screen. Perhaps your relay isn't working correctly, or at least correctly to match the pioneer. Try just wiring it to a switch and then to ground and see if flipping the switch a few times makes the video pop up.
If I unplug the relay the warning comes up. I can hear the relay clicking when I unplug it.
OK so tried a push switch today and still the same thing. If I hold the button and push the camera button I get the blue screen, which is good, however still only sound. If I let go of the button and push the camera I get the black warning. Either way if I just put the dvd in I can get sound, no video.
So I'm thinking its one of three things...
1. Somehow my Axxess/Metra GMOS adapter has something do do with it. I highly doubt it though
2. A have a setting thats incorrect
3. My HU is messed up and needs something repaired.
ace_800
ace_800
Okinawa, Japan
ace_800
Mike Mccabe
