Can't make up my mind on which way to go for amp set up
  • Thread starter g00d4me
  • Replies 0
  • Views 525
g00d4me
So after 5 years of not having a system in my car, I finally got around to assembling the necessary components to finish it off so I can finally get it installed.
My car is a 2009 Cobalt SS with the Pioneer system
Set up to go in:
Pioneer 4600bt
Canton QS 2.16 components for the front
no rear speakers
2 Pioneer TS-SW3001S2 shallow mount 12's
The problem I'm having is deciding on what amp setup to use:
First set up: MTX TC 4004 4 channel and a US Amps MD2D sub amp
Second set up: US Amps AX 5600 5 channel amp
Third set up: something different
The sub channel on the 5600 does 500 at 1 ohm and the MD2D does around 1500 at 1 ohm.
I would like to feed as much power to the subs as possible but since I have a small trunk, putting two amps in there might be difficult. Plus I've never heard a class d amp on subs, so I'm curious on the sound compared to an AB amp. I used to run a US Amps 2000x in my prior system but I had to sell it and I've regretted it ever since.
I was thinking of ditching the MD2D and 5 channel and get a 2 channel AB for the subs but since I can't make up mind, I figured I'd post something here to get some opinions and ideas/recommendations on what to do, stick with either set up or go with something completely different.
Also, I have a pair of old school Orion HCCA 6.5 2 ohm components that are missing the crossover.
It's the older a/d/s owned speaker system and I'm curious if I can still run those without the crossover? If so I might put those in instead of the Canton's.
Thanks
g00d4me
g00d4me
palm harbor, FL
g00d4me
