Can't get to some edges of my box, leave without silicon?
Big Dee
I'm building a slot port box for the first time and I'm having trouble with something (actually a couple things, but one in particular), I don't see how I can seal all of the edges on my box. Once everything is put together the edges that are behind the port walls will be impossible to reach, what should I do?
You think if all of the joints fit perfectly they will be airtight? Because they will all be perfect.
Good call on the filler, that would work, I really don't care what it looks like 'cause it will be carpeted.
i do a little trick befor i put the top of a box on. on the inside edges of teh box sides i lay a bead of silicone then on the outside edge i lay a bead of wood glue. then i put teh top on. the silicone seals the inside and teh wood glue, glues the wood together.
somthing like that.
somthing like that.
Your method FTW.
I knew I'd get a cool tip, thanks everyone.
ngsm13:
Maybe if I was Mr. Fantastic //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I can't get to it even through the speaker cutout.
what I would do is lay 45s on before I mount the top and use glue on the regular piece but silicone on the 45 top so when you lay it down the 45 is stuck with silicone //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif If your going for airtight that hardcore you might as well use 45s too.
Big Dee
Big Dee
Ohio
~Magick_Man~
