cani do this
  • Thread starter <jon>
  • Live activity
  • Replies 2
  • Views 1K
<jon>
Guest
can i run three dvc subs each at 2ohms and then wire them all together at the amp to end up with a two ohm load? this may sound stupid but if it works sweet.
jon- are they dual 2ohm voice coil subs
or are they dual 4ohm voice coil sub wired in
parallal (
meaning plus to plus and minus to minus
to get a 2ohm load)
also what kind of amp (brand) wil you be using for these subs and how much power does it
make at 2ohm bridge/mono
they are rockfords punch hx2s (dual 4 ohm) and i will most likely be powerinthem with a jbl 1200.1 can i run the three subs wired seperatly at 2ohms each to the amp and end up with a total of a 2ohm load from the three subs. if so kick ***
Guest
Doxquzme
    Aug 17, 2026
firey_kimchi
    Aug 17, 2026
