Can ZX2500.1 Kickers take 1 ohm daily?
YES IT CAN! I have run mine daily at .7 for the past 2 years with no problems at all.
While you have les, I wouldn't recommend it for everyone. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
You will need a very strong electrical system in order to run it at 1 ohm, and be forewarned that it WILL get hot.
I wouldn't recommend it for daily driving.
neither of mine get hot //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
well im just bought to get the amp it will be here tuesday, and i have to upgrade my electrical before i will even get it in, im just trying to get everything ready,
X2
I'd imagine that it would void the warranty as well...
because after rise means after the box rise causes the impedance to be higher not lower duh?
1 ohm load at amp with 1.5 ohms of rise means the amp after box rise will see 2.5 ohms duh?
did you really not know that?
not trying to be a dick just trying to educate you is all.
because after rise means after the box rise causes the impedance to be higher not lower duh?1 ohm load at amp with 1.5 ohms of rise means the amp after box rise will see 2.5 ohms duh?
And i know this, i am saying if his Impeadance is 1 ohm AFTER RISE no it wont last. Because that means hed wiring it below 1 ohm. If the amp is at 1 ohm BEFORE Rise it may rise to a stable impeadance of greater than 2 ohms or close to it.
crfrider
crfrider
Oklahoma
BassAddictJ
