Can your trunk be a box?
Meatwad1355
Can i reinforce the back of my rear seat, and use the trunk as a box?
I have a 91 civic sedan, and i took apart the back seat, theres a thin metal layer basically holding it together, if i replace that with wood, and place the subwoofer in it, will the trunk work as a box?
Ty for help,
ask if i didnt explain well enough.
??? what do you mean seal off the trunk? isnt it already sealed?
ya im basing it off the fact that your regular speakers use the trunk as a box, so why not //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
What you're talking about is called infinite baffle. Yes, you can do it, but the speaker must be made for such applications. Otherwise, you're just going to overwork the speaker and it'll be useless.
'regular speakers' or just speakers in general mounted to the rear deck dont rely on the trunk for any noise, they are just mounted there. they would sound the same if they were sitting in your lap...generally.
Subs, unless free air subs, do infact rely on some sort of box to produce the sound they are meant to.
Sorry I dont wanna explain it all, but most likely you'll be having to build yourself a box, ported or sealed, check the stickies...
So the subwoofer needs an enclosure for it to sound good?
and whats an IB?(edit: infinite baffle**)
im just working with what i got, and i thought it would be a cool idea, and maybe save me a bit of money, if i just put the speakers into the back seat, i havent seen it done before.. so i wanted to know if there will be problems from the setup, and thats maybe why others dont do it.
edit:
What kind of speakers are "free air" speakers?
Infinite baffle is a term used when the enclosure volume, whether it's a regular sealed box, or the entire trunk, or the attic of a house, is over four times the Vas of the speaker. Ideally, it's 10 times over Vas, but you won't likely get that out of a car's trunk.
Saving money is not usually the motivation for going IB. It will get you better SQ provided your subs can do well in it, and provide a very good frequency response...but be quieter overall when compared to a regular ported enclosure.
Meatwad1355
Meatwad1355
Peoria, Az
Meatwad1355
NorthFramingham
    Jun 30, 2026
