mgcauctions09
//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
If you want a .25ohm load...Ok so the final 2 wires from each group (wires that go into amps) I take both positives and twist them together and then twist the both negatives together?
That is wiring them in parallel. After you get them wired like that diagram shows, connect a + from one group to a - from the other group then the other + and - go to your amp.Ok so the final 2 wires from each group (wires that go into amps) I take both positives and twist them together and then twist the both negatives together?
I would say about 3%.hmmm ok, ill try that. How sure are you?//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
