Can you identify this electrical component? Help needed ASAP!!!
mavster
I'm repairing this amp, and for the life of me I can't figure it out...
Its for a lightning audio storm X1000.1D...
Thanks...
Looks like a homemade rectifier?? The jury is still out on that one without a schematic--- of MORE Concern is the brown (overheated) solder joints on the left -- the only one that looks good on that board is the one on the right... good clean traces, good solder joint.
I did a little mmore research..and my first answer is probably wrong... I spoke with one of my techs and we believe it is a thermo-couple. (homemade from spare parts it seems) It's basically a variable resistor that changes value as the heatsink heats up to keep the transistor's bias voltages balanced.
EDIT: hehe-- ya, we posted about the same time.... it is a variable resistor--the spade pulls/sinks heat from that "buss-BAr"/Heatsink.
//content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif A Cold solder joint can and will cause problems....The brown looking stuff is solder flux from an over heated iron and/or bad flux and/or not cleaning up afterwards...Seen it before...causes all kinds of problems when it heats enough to conduct...
gimme a min and I will see if I can find a parts house with em???
It looks like a thermistor which was described above.
For every component you could ever want/need, check out http://www.mouser.com They have tons of parts and great prices as well as fair shipping. It's where I find almost everything I need. Be careful when ordering parts though; read the spec sheet and make sure that it is the correct size. I've seen some thermistors that are only 1mm wide or so when I was ordering some of mine.
Good Link IMMACOMPUTER-- sounds like you have some experience in this field? I know just enough to get me in trouble but my Go-To person is pretty proffecient at it... it looks like He's in the switching power supply... look at the schematic. The resistor he's working with is there to stabilize the output verses heat.
I think if you're having trouble with the MosFets, cleaning and resoldering the connections is a good idea. After your done use a little bit of 90% alcohol to clean what residue is there. Let it dry off before adding power. It should only take a few seconds to flash off. Q-Tips works great for this my guru tells me.
Actually, I believe you're looking for a 50k Ohm Thermistor, not thermocouple. Looks like its a radial type soldered onto the board, and taped/attached to a spade connector.
Immacomputer beat me to it.
Are these the ones that look like doe or lamb skin? Just so used to the word Q-Tip ya know... LOL on the thermocouple.... sort of used the wrong term... blame the guru... she's the one who told me...LOL There should be a temperature rating somewhere on the part.
50k Ohm should correspond to 150C
Edit: NVM
Yup, that's what she was afraid of. I had her look at the photo and she basically said that a lot of companies will deface the original part number and sub their own. If there are no part numbers you may have to order by part location and description from the manufacturer. Problem is you don't know if you have a NTC or PTC thermistor to go with a generic brand.
PTC= positive temperature coefficient
NTC= negative temperature coefficient
mavster
mavster
New York, NY
sundownz
slater
    Oct 4, 2025
1aespinoza
    Oct 4, 2025
