can this be done?
im going to be installing the subs and speakers at different times...so i was planning to just use 8 ga when i do the speakers and 4ga when i do the subs. so is it possible?
are the knukonceptz KLM wire any good?
yeah it'll work, but that's not how i'd do it. I would just run 1 run of 1/0 and then get a distro block. that way you dont have to run diff wires later. just run off of the distro block.
Are you sayin' you're going to run 4guage wire from your subs to your amp? If so, good luck finding a sub that will accept 4 guage. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif I agree with everyone else, get a distro block. And then choose the appropriate size of wire for your amps.
no, 4gauge for the sub's amp. and 8gauge for the comp's amp. so i should just get a distro block?
blimblam
blimblam
new orleans
DaGh0st
michigan born
    May 14, 2026
michigan born
    May 14, 2026
