Can Kenwood Exclon run
Amp specs for KAC-X811D
POWER RATINGS (CEA-2006 STANDARD)
- Dynamic Power: 566 Watts
- Output Regulation: Under 0.2dB (4 ohms)
- R.M.S. Power Output (1-Ohm/1-Channel): 1016 Watts (1.0% THD+N)
- R.M.S. Power Output (2-Ohms/1-Channel): 919 Watts (1.0% THD+N)
- R.M.S. Power Output (4-Ohms/1-Channel): 533 Watts (1.0% THD+N)
- Signal-to-Noise Ratio: 74dB (4 ohms)
- Signal-to-Noise Ratio (Bypass): 74dB (4 ohms)
You'll want to wire the two subs for a final load of 2 ohms shown to the amp (as your options with two dual 2-ohm subs on a monoblock will be either 0.5 ohms, 2 ohms, or 8 ohms)
Wiring them for 8 ohms would be a waste. Wiring them for a 1/2 ohm may not be too good of an idea as I don't think that eXcelon is stable that low. Wiring them for 2 ohms will give each sub a hair under 460 watts at 14.4 volts. As those T1's are rated for 600 watts RMS that ought to bring 'em to life pretty well.
crazy12345
crazy12345
clarksville TN
jsloan10
