Can I wire a 3.5mm plug directly from my speaker wire hookup on the back of my Amp
jbander
My car radio died, so I got a small amp that has fm and I have to wire power to it. then all I have is my speaker wire connectors at the back of the amp . So I can wire it to my speaker system . It will take a lot of digging around. which is a hassle but if I can wire from my speaker terminals to a 3.5mm plug . I can then simply plug it into my radio. which I have been doing with my cell. So I'm just thinking about getting a cord to plug into the cigarette light socket and I'm hoping I can wire from my speaker connections to a 3.5mm plug. Thanks.
You could do amp to speakers.
3.5mm to RCA to Amp.
It would work, then you simply plugin your source (phone) for music. It won't be the best but it will work
I'm confused with your post and what you're trying to do.
Ya I'm sorry about the confusion , The radio in the car has a 3.5mm Input to plug into, I know it works because I've used my fm in my cell plugged into it. The only outlet on the amp(that has a FM in it)that I just purchased , is the connectors for the speaker wire. If I use those directly to the speaker , it will not be as easy as being able to plug the 3.5mm plug directly into my radio in the car from the amp.. Since my radio is already hooked to the speakers.-- So the question is can I wire the speaker wire from the amp, to a 3.5mm plug. Simplifying the project.
jbander
jbander
Mpls Mn
jbander
