Umbra
Hobbyist & CA Tenderfoot
Can you stick a high impedance load on an amp?
Here's the situation: I have a pair of 4 ohm DVC subs. They're rated 400W RMS each. I have an amp that does 500W @ 4 and 900W @ 2. I've heard mixed things about its 1 ohm stability, so I never tried it and unfortunately I can't wire the pair to 2 ohms, so I've been running them at 4. One of them I need to fix up, so I was wondering if I could wire the remaining sub to 8 ohms and run it safely to get some bass in the mean time.
Is the reason there's no 8 ohm rating is because it's uncommon to see that in car audio and impractical to use a 2 ohm amp at 8 ohms, or is there another reason? If I ran it like this, what could I expect to see the amp put out - roughly? 300W?
I actually have another amp in my possession I'd planned on using for the pair that does 750+ @ 4 and 1. It also does 300+ @ 2 ohms in stereo, so I can use that for the time being if need be, but I'd still like the answer to this question for curiosity sake.
