can i use a 4 channel amp for only 2 door speakers?
  • 5
some 4ch amps if you just bridge them you will get a summed output to the speakers instead of left and right signal. What kind of amp is it? You might have to use y splits and wire ch 1&2 to only left signal and 3&4 to only right signal then you will get seperation.
10
444
It is Opel (Vauxhall) Astra J 2011 model, I change the HU to Kirinavi 10 inch screen. The factory speakers are Infinity and would have come with a...
660
Okay, I'll bite. If you're going to get rear speakers, get the same ones (model type, doesn't have to be the same size) that you have up front...
I would keep the amp you have and keep the components. Place the components in some universal door pods, and look at getting a powered SAS 8"...
13
zanderson45
zanderson45
Morrow, Ohio
CrossoverOre
    May 10, 2024
3toneEYZ
    May 10, 2024
