can i stap,link, 2 memphis st1000d
thanks .... how does that work like what if the sub is a dvc 2ohm how would that work a amp on each vc or what
dont run that st amp @ .5 ohm it will smoke the really old st1600d were .5 stable but that was yrs ago. just voltage match each amp to within 1 volt on the speaker output (roughly 44 - 46 volts a/c current for 1000-1100 watts) using a 50 or 60 hz tone burned to a cd. no speaker hooked up at the time.
AGAIN sonic does the same install stuff for free as well! Get a head unit with 4v preouts and 6 rca preouts as well they will be setup as front...
19
It's supposed to be, that you're not supposed to be able to mess with/adjust your GPS settings while you are driving, because it's a hazard. A...
927
5 times so far and probably counting. How many times are you gonna post the exact same ignorant nonsense, and not actually answer my question...
19
If you can get the app on the head unit, im sure it could. Not sure how you'd get the app on it. However, you might be able to use something like...
You can get a cheap fuse block (Scosche brand) at Walmart for less than $15...why leave it to chance? Put a fuse block in and don't worry about...
1982atm
300c srt8 pony killer
1982atm
nap town
SicAudio
    May 16, 2024
    May 16, 2024
