Can I Hit 150+ DB's
wafsman
ohio
Is it possible to hit 150 or more decibels with a pair of these speakers?
American Bass VFL Series DVC Subwoofers
Common Features:
* Dual 3" 6 Ohm High Temperature Voice Coils.
* 1.4" Wide Multilayer Foam Surround for Better Stable Linear Exclusion.
* Non-Pressed Black Treated Paper Cone.
* Vented Deep Bumped Back Plate
* 180 Ounce Double Stacked Magnet Structure
* Dual Black Mirror-Image Spiders For Linear Stability.
* Sleeved High Power Tinsel Lead Wires to resist Lead breakage.
* Blackened Motor Parts for Superior Heat Dissipation & Long Life
* Hyper extended Pole Piece Increases Accuracy, raises Induction.
* Deep Bumped Back Plate to Increase Power Handling.
* Uni-Rubber Gasket for Airtight Seal in Mounting.
#VFL12 - 12" 1500 Watt Woofer
* 750 Watts RMS
* 180 Ounce Magnet
* Efficiency: 91.75dB
I was thinking of a ported box with 2.5 cu ft per speaker and tuned to 29 hz. I was thinking of using an Audioque 2200. Does anyone think this is possible with that setup? Or would I have to do something else to get on that level?
Common Features:
* 750 Watts RMS
* 180 Ounce Magnet
u wont hit 150 tuned that low thats for sure. i know my neighbor does mid 150's with 2 of the vfl 10s but its in a crx and with like 5k on each
who cares about numbers anyways, as long as its loud to you that's all that matters. Its not like you ride around with "150db" on your car. even if you did, barely anyone would know what it meant
if you need a 3d model of that, shoot me a PM and we can work something out
this is the last one that i did.
I remember when the guy did the installation, he kept focusing on the loc, I remember him constantly talking about that and thats a piece he...
31
4K
Most likely your ground. I've seen that happen, the sub looks like it's playing a 5 Hz note. If one piece of equipment doesn't have a good ground...
Cool. If it came with a 2 year warranty from an authorized repair shop less than 30 miles away from me I might consider buying a few. You...
54
7K
I wouldnt spend the funds on that amp if you have no way of knowing it works or not. Id purchase another 4 ch for that kind of money. You just...
wafsman
wafsman
ohio
hockeytoker
just call me KeV
    May 1, 2024
just call me KeV
    May 1, 2024
