can i do this???
mikeiowa
head unit = jvc sr85bt
sli 2000.1 monoblock
2, polk audio 10 inch subs
4 kenwood 6x8 speakers
wanting to know if i can add a dual xpr 540 4 channel amp to this system???
would like to dedicate the monoblock to the subs and amp to the speakers..
but i have no idea how to wire it up..any help would be greatly appreciated
If the HU has pre-amp outputs for the mono and front and rear then you’ll just run patch cables from each to the amps. As far as power, you can do 0 gauge into a distribution block, and then to each amp. Or you can do 2 runs from the battery... 0 gauge to the mono, and 4 gauge to the 4-channel.
i have front,rear,left,right rca plugs
Have to use a set of rca splitters then and I would split the fronts so they are used for the front & rears at the same time so the rear rca's are used for the subwoofers since they can be controlled from there. Something like that below or w/e brand you want to use
Then just run the Front outputs to the 4-channel, and the Rear/SW to the mono. You should be able to run one remote wire and splice it into both amps for the turn-on. And since you'll be running two power cables you may see a drop in voltage and dimming lights... then you may need to upgrade your electrical (i.e., big 3, alternator, battery).
mikeiowa
mikeiowa
des moines ,iowa
mikeiowa
AJ (ACE)
    Jun 28, 2026
Mike Mccabe
    Jun 28, 2026
