I have a 4ohm DVC sub, I wanted to know if I could hook up my Kicker KX600.4 to each of the coils. The amp does 300 X 2 @ 4ohms. So can I hook up each coil to 1 channel bridged on the amp?
sounds like it would work but dont quote me on it... invest in a MM and check the final ohm load and total watt output after u wire it up. then u will know for sure but if u have a sub setting on ur deck then turn it all the way to 0 before u test it and set ur gain low to start then turn it up gradually checkin both ohms and watts after each time u inc the gain on ur amp
Assuming each coil is 4ohms.....Yes, you can bridge the amplifier and run one coil per bridged channel. So wire one coil to the bridged channels 1&2, and the other coil to the bridged channels 3&4
For best performance be sure to feed identical signals to all channels and use a DMM to set the gains as close to identically as possible.
possible, and if you do it right it should be fine, but i wouldnt want to do it. better off using it for some components and stuff and then getting a 600.1 //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
