Amplifier Question
  • Thread starter <Troy>
  • Live activity
  • Replies 3
  • Views 1K
<Troy>
Guest
I recently bought 2 Audiobahn Alum12X's, and am wondering what type of amp I need to push them. the RMS is 1000 each, but i have no idea how ohms and stuff like that work into the picture, can someone let me know what a strong but safe way to go would be? thanks
here are the stats on one sub:
120 oz. Double Stacked Strontium Magnets
Power Handling: 1000 watts R.M.S.
Frequency Response: 18Hz – 500Hz
Efficiency: 96.4dB
3 Inch 4-Layer ASV Voice Coil
Dual 6 Ohm
3 Ohm or 12 Ohm Operation
thanks again
troy
If you wire em both in parallel then you will have a 1.33 ohm load so you are looking at a one ohm stable monoblock or a high current amp.. The big Audiobahn amp will do..Or for around the same money look into Earthquakes PHD2 (shredder) Autotek also has some monsters that could do it..Just for a few to look at.
Mike
good choice on the speakers. I was gonna get thoses but then changed my mine. those Earth Quake amps should push thoses speeakers AFTER all they dont call them earth quakes for nothin
Guest
azbass
randy hagan
    Jul 15, 2026
