can i do my own Bench Test
Don't forget non-inductive resistors. As far as power supplies, I find that a car battery works fine. But than again, you can't find out what your amp would do at 14.4 volts with the battery.
Assuming you have everyhing you need to take the measurements why not bench it in the car at 14v?
The idea of using a bench supply is that the supply voltage generally is more stable (if you have a sufficient PSU, of course //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif), doesn't have the voltage drop that you incur in the vehicle.
406er
box builder extraordinair
406er
Winnipeg,Mb
_DjScrew_
