Hi, I'm looking for an amp that can power two 4 ohm subwoofers. The clue is that it has to be as cheap as possible, while capable of producing the required amount of power. I would like to have about 150W rms for each driver. I've been looking at a Blaupunkt GT-450 amp, and was wondering if I can bridge this to a 2-channel amp, giving me 160 watts rms per channel? If not, how much power can I get out of it? The specs can be found at:
http://www.bluespot.co.uk/stock/mpa500.asp
Four channel mode max power: 4 x 100W into 4 ohms
Four channel mode max power: 4 x 160W into 2 ohms
Four channel mode RMS power: 4 x 50W into 4 ohms
Four channel mode RMS power: 4 x 80W into 2 ohms
Two channel mode max power: 2 x 320W into 4 ohms
Two channel mode RMS power: 2 x 160W into 4 ohms
