Can anybody please help design an enclosure for 2 zv4 15
When I click the link it takes me to his home page I guess you would call it don't see any video but I am not stuck on strapping them they do not have to be strapped at all I just thought it was better when running Subs in a shared chamber so you have the exact same signal and power going to each sub so if I don't strap the amps should I build the box to where each sub has its own chamber
It literally should just show the video not take you to any link or page.
youtube search this "gain match amps identically" and it should be the first vid you see from barevids.
Thank you guys for the help I definitely appreciate it very much and I found the link to the video in my email for some reason it definitely makes sense what he says so I probably won't strap the amps definitely going to watch it again before I wire it up and probably try what he says first and Boomin Tahoe was right I can go all the way up to the first set of measurements that I listed and still have enough room for Port clearance I'm hoping that these amps will put out around 9 K before rise since they are going to be at .5 each but like I said they will be at 2 ohms each until I get the high output alternator so probably going to be around 4K before their rise so if you use 7K like you said it should work out great
Also I was wondering what kind of glue you guys usually use for MDF normally I use Titebond or subfloor adhesive I know it sounds stupid but it works really good also do you guys prefer screws or brad nails or both
titebond 2 or 3, either works. Nails for stronger bite aka bigger jobs like walls etc... Brads for fast enclosures aka anything thats not a wall.
So 2in Brad's will be good for my box that's what I normally use anyway and never had a problem but this will be my biggest build but not by far
the nails and screws arent doing anything other than keeping the wood tight in place so the glue can cure properly. As long as its glued well, it doesnt matter what you use. Some people with lots of clamps on hand dont use any screws or nails at all.
Jeffro83
Jeffro83
Indianapolis, IN
Jeffdachef
