sundownz
Pro Seller
Supporting Vendor
Glad to see some good information on HO alts put out there... I've had some CRAP high output alternators in the past.
Ive never heard of that brand //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gifGlad to see some good information on HO alts put out there... I've had some CRAP high output alternators in the past.
see EA, they go by the same name. mine was junk and killed itself at idle with no system in the carIve never heard of that brand //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
don't forget that the amperage output gets lower the hotter the windings become. All these pretty graphs that these companies are posting on their sites concerning RPM vs Amperage output do not reference coil temps //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
EA ftlsee EA, they go by the same name. mine was junk and killed itself at idle with no system in the car
DC ftwHe speaks the truth. Rob personally gave me a tour of his shop, and gave me a crash course why his alts do what they do.
Matter of fact rob I have to catch you at a good time to speak about a few things.
And my hood on my crx is always open to be the test subject for your alts.
Honestly... between Brandon (employee) and myself we have four EA alternators with no problems at all. I'm sure mileage varies as with anything, of course //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gifsee EA, they go by the same name. mine was junk and killed itself at idle with no system in the car
I never really had a problem with mine either. Just a simple bearing noise ,replaced works fine. Still was putting out amps and plenty of voltage when bearing was making noises.Honestly... between Brandon (employee) and myself we have four EA alternators with no problems at all. I'm sure mileage varies as with anything, of course //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I dont remember exactly what engine RPM, but alternator RPM was between 2200-2250..
The only reason I didnt have a laser tach on the pulley is I was already holding the camera, and the 2 meters.. I'm not an octopus... Just a tip though, look at the belt in the video CLOSE, if you can see the logo on the belt going past and it's not a blur, that car was at normal idle...
I'll entertain any kind of meaningful discussion of the pro's/con's of high output alternators, and the difference between large alts like Leece Neville, Niehoff, and units like we build.. I have nothing to shy away from..
Are the bigger alts more capable of big numbers, no doubt.. But they are used in TOTALLY different environments and are built to do it for long periods of time.. If you want to get into ratings and BS, Leece Neville is the WORST offender there is for over-rating their alternators.. Their 320 amp unit is rated 320 @ 72°f but your **** lucky to ever see 250 hot..
Like I said in an earlier post, the ONLY reason you all are so skeptical is because there are so many shady companies making BS claims and not backing them up that when something like this comes up your first instinct is to call BULLSH*T... It's like the boy who cried wolf, many times he cried wolf, and many times there was no wolf, so when he did cry wolf when there WAS a wolf, nobody believed him...
Did you ever think that maybe, just maybe in the last few years that alternator technology, and increases in efficiency has become such that alternators that will do 200 amps at idle ARE possible?? I got one word for you folks, efficiency, efficiency, efficiency....
I have the video of one of these on the test bench that was shot with 2 tachometers, 2 voltmeters, and 2 ammeters that all say the same thing.. And if anyone doesnt believe me after I upload that, then like I said earlier the doors always open for you to come see it yourself...
mine was rated for 200 amps max. it did 158 at 6k alt rpm ice cold. i would mabye see 120 hot at 6k alt rpm. i think it did something like 67 amps at idle.Honestly... between Brandon (employee) and myself we have four EA alternators with no problems at all. I'm sure mileage varies as with anything, of course //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
