Calling all box geniuses! Need help for 15" box.
BLD 25
Hey, i have recently purchased a very inexpensive ED e15k (made by destjl, the old RE buildhouse), and i have a couple of problems. I have a dodge intrepid with a rear shelf that comes down and only allows for a 14" tall box. I know i can angle the front of the box, and that would work ok with a round port, but what about a slot port?
I know the recommended box is 2.5-3.0 cubes net, the woofer displaces.08, and i would like to port around 32.
specs:
http://www.edesignaudio.com/edv2/product_info.php?cPath=37&products_id=443
Can i have the slot port come out the side?
Any other tips? I have been using the calculators from:
http://www.audiogearreviews.com/tech/tools/box_calculator-wedge.asp
http://www.the12volt.com/caraudio/boxcalcs.asp#wed2
http://www.reaudio.com/speaker_box/LPort_Box_Calc.html
Thanks!
One thing i was thinking about doing was because the shelf only extends out 10inches or so, i could build a 14" tall box, and then build it up 2" higher in the front for a couple of inches back so the sub could mount in and fit. I could just calculate the volume of that added rectangle on top and add that to total volume. Would that work ok?
Oh, i dig the RL-P, but i have a 12" version of the e12k, and it holds its own pretty well against the RL-P, and i got this 15" for $45 shipped, so i figured why not try it.
like this?
As long as you angle the port inside to match the angle of the baffle board, you can build it without having to put in the drop. Like this,
The design the JBL gave you is super, as long as you can get enough port area, that enclosure will fit sweet.
Hope we have helped.
BLD 25
BLD 25
Carbondale, IL
BLD 25
