calculating port area
Bender.
The Original Offender
my box is 11 cuft and my external dimensions are...
53.25" wide
24" tall
18.25" deep
i will not be using a side wall as part of my port...it will be in the middle between the subs...can someone either give me a link to a calculator or just do it for me? thanks
edit: o and btw the subs will be inverted so they dont count in displacement...and i want it tuned to 35hz
edit: i just downloaded winISD and i get a port that is 5.51" x 5.51" x 2.23"......something seems wrong
edit: o i think i have figured it out...you have to put in your opening size and it will tell you how long the port needs to be
Your not using enough port area.
Using a kicker two 15" L7's as my model
I figure you should build a 10" x 10"
port that is 13.22" deep. The net
box displacement is right at 10.5 cubic
feet.
Your not using enough port area.Using a kicker two 15" L7's as my model
feet.
after i figured it out i got a port that is 22.5" tall, 4" wide, and 11.3" deep
would this work?
edit: same airspace
I ran your enclosure in bassbox pro 6 and the above port and the box in your first post would put you at 35.55hz with a port area of 90sqin. It would work well with your subs //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
yep thats what i was aiming for
dear god i have tried winISD, re, and carstereo.com and i have gotten 3 different measurements
all are 22.5 tall and 4 in wide
winISD-----11.3
re-----------13.25 turn and go 8
carstereo--8.17
You could do something like this and it will work:
That's right around 9 cubes tuned to 35hz with 135in^2 of port area. You will need bracing on that back wall though.
Bender.
Bender.
tennessee
Immacomputer
BP1Fanatic
BP1Fanatic
