Cadence SQA-4 or MB Quart NAU-460?
  • 1
sc_beerbarge
Looking for a cheap 4 channel amp for the boat. So far I have it narrowed down between the Cadence SQA-4 and MB Quart NAU-460. I'm open to both or other reccomendations. The amp will power (2) 6x9s and (2) 6 1/2 speakers.
Thanks,
SCBB
SQA-4
MARINE 4 CHANNEL STEREO POWER AMPLIFIER
SPECIFICATIONS:
4 Ohm RMS Power: 4 x 60 Watts @ 13.8 Volts
2 Ohm RMS Power: 4 x 100 Watts @ 13.8 Volts
4 Ohm Bridged RMS Power: 2 x 200 Watts @ 13.8 Volts
Frequency Response: 20Hz - 30kHz
S/N Ratio: >100 db
Damping Factor: >200 @ 100Hz
Minimum THD:
Input Voltage: 200 mV - 8 Volts
Dimensions: 13" x 11" x 2.75"
FEATURES:
High Speed Mosfet Power Supply
Lucite Encapsulated Angled Terminals
12 dB Crossover Circuitry
Fully Adustable Crossover
Bass Boost Equalization
Lucite Encapulated Terminals
2 Year Warranty
or
MB Quart NAU-460
Features:
4-Channels x 60 Watts At 4-Ohms
4-Channels x 90 Watts At 2-Ohms
2-Channel x 180 Watts At 4-Ohms
Frequency Response: 10Hz~4KHz
Signal To Noise Ratio: 93dB
THD %: 0.05%
Variable High-Pass: 250Hz~4KHz
Variable Low-Pass: 40Hz~250Hz
45Hz Bass Boost: 0-+6dB
Protection And Power LED Indicators
Bass EQ: 45Hz Bass Boost From 0dB To 6dB
Frequency: Variable Based On Filter Selection
In Low The Frequency Is Variable From 40Hz To 250Hz
In High The Frequency Is Variable From 250Hz To 4KHz
Filter:
Low: Selects Built In Low Pass Filter
Flat: Bypasses All Crossovers For Full Frequency Range Operation
High: Selects Built In High Pass Filter
Input Level Sensitivities Are Variable From 0.2Volts To 6Volts
Capable Of 4-Ohms Or 2-Ohms Operation Per Channel,Or 4_Ohms Mono
Dimensions(L/H/W): 320mm x 52.07mm x 240mm(12.6" x 2.04" x 9.44")
SPECIFICATIONS
Amplifier Class : Class A/B
Number of Channels : 4-Channels
Maximum Power : 360 Watts
RMS Power Output @ 4 Ohms : 60 Watts x 4-Channels
RMS Power Output @ 2 Ohms : 90 Watts x 4-Channels
Bridged Power : 180 Watts x 2-Channels
THD (Total Harmonic Distortion) : 0.05%
Signal-to-Noise Ratio (dB) : 93dB
Frequency Response (Hz) : 250Hz~4KHz
Built-in Crossover : Yes
High-Pass Crossover Frequency : 250Hz~4KHz
Low-Pass Crossover Frequency : 40Hz~250Hz
Bass Boost : 0-+6dB
Bass Remote : N/A
Fan Cooled : N/A
Fuse Rating : 25A x 2
Dimensions (Width x Height x Length) Inches : 240mm x 52.7mm x 320mm(9.44" x 2.04" x 12.6"
Approximate Weight : 9.50 LBS
First of all you would want to verify that it works. Next, don't expect to get much out of it. There's a rather finite life expectancy on...
Get your Coupon RIGHT NOW!!!🥳🥳🥳 Let’s celebrate the upgrade of Cadence Sound Website! Take this chance to get the 10% OFF coupon which has no...
The Timpano amps are also small. I bought a small 1400 watt Timpano mono amp. I was impressed by the power I could get from it, but they have a...
15
Hello, I have bought a set of speakers but I want some recommendation of an amplifier that can work very well in them. 1 pair of RS1-216 1 pair of...
sc_beerbarge
sc_beerbarge
Upstate, SC
sc_beerbarge
    May 23, 2024
SPLBassJunkie
    May 21, 2024
