Cadence "competition sub"
eh,...13lb magnet... my dustcap weighs more then that //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
* DIRECT CONNECT 10 GAUGE WIRE CONNECTION
* X-MAX 26-30 PEAK TO PEAK
* WASHER PLATE THICKNESS 14mm
* ONE-PEICE EXTENDED POLE TECHNOLOGY
* SURROUND STICHED TO CONE BODY
* FIBER REINFORCED PAPER COMPOSITE CONE
* INVERTED POLY 3-D DUST CAP
* GRANITE FINISHED BLACK TEXTURE COATING
* MAGNET MOTOR HEATSINK WITH HEAT PUMP EFFECT
* QUAD LAYER, LINEAR PROGRESSIVE CONEX SPIDERS
* INTERGRATED HIGH CURRENT ROUND TINSEL LEADS
* 3" BLACK ALUMINUM ANODIZED VOICE COIL FORMER
* HIGH POWER FOUR-LAYER VOICE COIL WINDING
* ULTRA SATURATED, HIGH BL "MAGNETIC MOTOR GAP"
* LARGE DOUBLE LAMINATED SURROUND
Specifications:
o 1000 WATTS RMS
o 2000 WATTS PEAK
o FREQUENCY RESPONSE 25 - 500Hz
o MAGNET WEIGHT 14 lbs.
o SPEAKER WEIGHT 35 lbs.
o SPL @ 1w/1m 89dB
o MOUNTING DEPTH 7.9"
o 1 Year Warranty
skylineTT
bass=sekz
skylineTT
Houston/Dallas
Papermaker85
