Cadence amp
netzero
USMC
between a
Cadence TX-A750D
2 Ohm RMS Power: 1 x 375 Watts @ 13.8 Volts
Frequency Response: 20Hz - 500Hz
Damping Factor: >300 @ 100Hz
S/N Ratio: >100 db
Minimum THD:
and
Profile AP1000M
RMS power output @ 2 Ohm 1 x 500W
Frequency response 20HZ- 250HZ @ ? Volts
signal to noise >103DB
Damping Factor 300
Which will be better, in the difference between 375 and 500 watts?
Cadence, based on personal TXA experience as well as outstanding customer support by Jason in NJ (call the main number and ask for him, he'll field all of your questions)
..you have 2 DVC 2 ohmers?? Don't run the TXA line at .5 ohm... If you only have 1 Dual 2 ohmer, then you have a 1 ohm load... if you have two, then you will have to stick to wiring in series to get 4 ohms on each and the parallel to the amp for a 2 ohm load...
Ya just checking im going with 2 Ohms, maybe get one more sub and run it at 1.33 in the future. 375 watts RMS, is that under rated by cadence, is it gonna sound louder than that?
netzero
USMC
netzero
Columbia, SC
netzero
