Hey everyone..like in my introduction I'm getting back into car audio after a few years on the sidelines and now I'm ready to get back into it.
I don't have a ton of money to spend. So, for and amp under $300 I've narrowed my choices down to the Cadence A7 (which I've had before and it rocked) and a Punch 150 "25 to Life". I've heard good things about the Punch and it's underrated..my plan is to have two 15's (that's the next dilemma) and I'm into the SPL type systems but want to have enough control that I can pull it back for when I don't need tons of bass. The Cadence did that well but was wondering if the Punch might be better or what..opinions..suggestions..Thanks!
Specs?
Cadence A7+HC:
1200 watts Specs: Mono Block, 500W RMS x 1 @ 4 ohm, 800W x 1 @ 2 ohm, 1200W x 1 @ 1 ohm, blah..blah...
Punch 150:
* Rated Power: 75W x 2 (RMS) @ 4 Ohms; 90W x 2 (RMS) @ 2 Ohms; 180W x 1 (RMS) @ 4 Ohms Bridged (Actual "Birthsheet" Power Rating of these amps are 323 Watts per channel at 4 Ohms)
* Crossover Controls:
High Pass (HP): 40 to 400 Hz, 12dB per Octave Butterworth
Low Pass (LP): 40 to 400 Hz, 12dB per Octave Butterworth
* Tone Controls: Bass 0dB to +18dB @ 45Hz
* Signal Input: Low Level - 1 RCA Pair
* Signal Output: Low Level - 1 RCA Pair
* Power Input Connector and Guage: Block Type / 4 AWG
* Speaker Outputs: Screw Terminal Barrier Strip / 8 to 18 AWG
* Heat Sink Type: Cast Aluminum
* Convection Cooling
* Power On Indicator
* Class A/B Circuit Topology
* Frequency Response: 20 to 20000 Hz +/- 0.5dB
* Dimensions: 17.6"L x 11.2"W x 2.6"H
* 4 Guage Power/Ground Connections with built-in ATC Fusing
*Connector Cover
* Focused Mass Heatsink Design
* RCA Pass-Thru
* Stealth Connections
* Thermal Sensing
Specs?
Cadence A7+HC:
Punch 150:
*Connector Cover
* RCA Pass-Thru
* Thermal Sensing
