cadence A7 HC at .5 daily???
michaellane
Anyone have any info on this? I want to make sure it will handle it without a issue. Im aware it wont see that with rise and everything im just asking before I do it or buy another amp. I have the electrical to do it. Big 3, HO alt, 2/0 welding cable, 50ah batt up front and 4 or 5 small 26ah batts in the back. The amp will actually be seeing .67 but figured id ask about .5
A lot of 1 ohm setups are probably sitting around .67 ohm anyway, shouldn't be a problem unless it's endless sinewaves in hot weather. Give it a try and see if it goes into thermal. If so, then...
michaellane
michaellane
tx
snoopysnooper
