CA, check my math
maldecido33
MSEE
Just double checking my math :)
First scenario:
2.0cu ft after sub displacement
32" of port
6" diamater round port
32.344 Hz
OR
Second Scenario:
30" of port (per port)
two 4" diameter round ports
32.057 Hz
Both of these work out?
Enclosure is for a 12w7, fyi
You are correct. But that port will have to go on the outside of the box. Because as soon as you put the port in the box, it will effect your net volume. Lowering the internal space and raising the effective tuning.
Option 1
2.0ft^3 net volume.
Box needs to be at least 2.52ft^3 for the port displacement. Not including driver displacement.
Option 2
2.0ft^3 net volume
Box needs to be at least 2.44ft^3 for the port displacement. Not including driver displacement.
What ever the driver displacement is add it to the volume I supplied and you're good to go.
Option 1
2.0ft^3 net volume.
Option 2
2.0ft^3 net volume
the actual ideal net volume for my driver is 1.75 cu ft (12w7) I had the .14 driver displacement factored into the volume I used above. i figured you used the net volume before port displacement in the formula. so, i need a box with a volume of 2.186ft^3 before port or sub displacement?
You use the gross volume less all displacements in the formula
If you calculated based on 2cuft, then after port and sub displacement you need a net internal volume of 2cuft.
Like squeak and I said. Your final required volume (net volume) is after all displacement. IE - Bracing, port, driver.
If you need 2ft^3, and you have .14 driver displacement.
Option 1
2.66 total box volume before displacements.
Exaple a box of 16.5 x 16.5 x 22 with .75" build material = 2.67
Add the speaker and the port in there and you have 2.01ft^3
Option 2
2.58 total box volume before displacements.
maldecido33
MSEE
maldecido33
Lubbock, TX
tRiGgEr
