bypass info
What brand? Id highly recommend the ones from bypasskit.com. DEI just took them over..
Trailblazer: GMDL-BP, this will take care of trasponder and doorlocks. If for whatever reason you dont want doorlocks, you can use just a straight GMBP.
Grand Prix: PKU-GM. this will only do transponder..
cool.
the GMDL-BPs are great and so reliable, and work for the majority of GMs out there now, jsut grab the data wire at the OBD2 connector and then your usual ground/constant/trip (and locks from starter). Doesn't get easier...
I dont think those gm's use transponders, should be passlock II. Just get the 1700g, its a dei product, uses dei wire colors and does (lock, unlock, factory arm/disarm, doorpin, dome sup, and passlock bypass.
passlock II is what i meant. same idea... its just in the collar.
just use a 555L on the grand prix, then you dont have to worry about loosing a key... i dont even think a U will work on that car
edit: nvm, just looked at directechs and it said you can use a 555gw or a 556uw..
lucky you have directechs. i gotta find a way back in there. might be paying someone some money to get me registered. but ehh its not my car and he knows he will loose a key so he is cool with it.
passkey III can be bypassed with data, whereas transponders in fords, nissans, and other require the key. I wouldn't use the 556u in a gm.
THUNDERBIRD
THUNDERBIRD
LANSING, MI
THUNDERBIRD
