Buzzing in sub...
bigwheel15
Ooh Yeah!!
I have a sony sa-wms23 powered subwoofer, the problem with it (besides it being sony) is it makes a low buzzing noise for about 3 seconds then it will sound normal for about 3 seconds then continually go back and forth between the two doing this. What could be the cause of this? How would I go about solving this noise?
I think it being a Sony is part of the problem //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Sounds like some hum is getting into the amp, might be AC hum or something.
I plan to, believe me. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif I guess ill try the ferrite filter, if that doesnt work ill come back and go from there.
lemans couldn't tell you how to breathe much less fix something
BIGWHEEL15: my sub buzzes, can you tell me why????
LEMANS23: ....you probably blew the subs from underpowering them
When my cell phone is around my Logitech z-680's, they buzz and hum and crackle. When I move it 5 feet away from the amp, it goes away. just a thought
Maybe your amp is set on Full or HP filter. Set it to LP if you are powering subs. I had this problem also until i started messing around with the amp.
It's a home theater sub...the onboard plate amp is not going to have those options, as it's only designed for powering subs, and nothing else //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
bigwheel15
Ooh Yeah!!
bigwheel15
Fort Worth,Texas
PV Audio
michigan born
    May 14, 2026
michigan born
    May 14, 2026
