Burning Wood Smell Port
shammyhavik
Just tonight the port has started spewing this smell like burning wood. Definitely not the coil smell that I am used to so its making me question what is going on here.
My hypothesis is some leftover old sawdust got kicked up into the coil and burned up.
Does it happen at certain times? like when your going full tilt or jjust daily music?
You could pull it out. run it and see if there is any sawdust coming out.
Hell you could put some fragrance oil on the VC and have a great smelling bass. lol
I ran the speaker wire from each sub out the port. both at two ohms then ran into the amp using both + and - terminals to get a 1ohm.
I **** you not i have a earth shattering increase in DB's, not a single heat spot on the amp or dustcaps, but a little smell when i got real crazy with the knob at idle.
I am gonna get this ***** term labbed
shammyhavik
shammyhavik
cali
shammyhavik
