Building my new garage. Osb or Sheetrock interior walls??? Can't decide.
if its not a garage that you do a lot of work in, mostly used just for parking cars, i'd go with sheet rock.
if its gonna take some abuse go with osb. i've even seen people use 1/8 or 3/16 masonite, it will look like shit brown all over your walls, but it beats having to repair nicks and gouges in sheet rock all the time.
Yea I'm still kind of deciding. Doing drywall doesn't bother me. Been a carpenter for 10 years and done thousands and thousands of footage in drywall and taping. If I did drywall it would just be firetaped ( fill all the screw holes and just string a line of tape with the banjo then smooth it out. Nothing fancy.
If I do osb. Well that's pretty simple. I'm building shelves along 2 sides ( back and right of the back) and I'll have all my tools tool chests etc in one corner and a couch and tv more than likely on a mount in the other area. Yes this is gonna be my "2nd home" I guess since all guys need a good garage to mess around in and break or fix sh1t.
Won't be doing much mechancal work with tons of dirt grease etc. Just whatever. Brakes struts minor engine stuff. Also will be for my woodworking and build projects. Another thing about putting rock up is that it will be a shitload brighter which is always nice. Even though I'm gonna have about 12 of those compact 60 watt florescent bulbs that are about 5 frikkin times brighter than a standard 60 watt lightbulb
sheetrock. You'll save a ton down the road on lighting, cause OSB takes more coats of paint to cover. Also, you may want to move some shelves/cabinets around later, and it's much easier to fill the holes in sheetrock
never use sheetrock in a garage thats designated as a shop..
I have a 35x35x15 shop and I used OSB and then put 2 coats of semi gloss paint on it
Its super durable,cheap and looks great plus I can throw a brick at it and the shit wont crumble
like sheetrock will
hzsogood
**The Clean South**
hzsogood
TX/MN
SPLaudio
