Manhattan
I'm putting a "system" in a Jeep CJ. The Jeep doesn't lock. It will almost never even have a top on it. So, the system will be cheap... and hidden. I'll have two speakers behind the dash, and a small 4-channel amp hidden behind the dash. I'll have RCA and power/ground cables run to the back of the CJ for a removable box - with (probably) just 2 6x9s.
I'm not planning on using a headunit/receiver. I want to stream directly to the amp, using an iPhone. I've seen tons (!) of bluetooth adapters/receivers, but they all run on battery power or require a 120v plug. Surely there's a bluetooth adapter with RCA plugs that can be hard wired to a 12v system... right?
Thanks!
Thanks!
