brmcm15
Oh lawdy!
ok found what i was looking for and i have a couple questions...
first here is the pin location of all the wires on my harness and all of them are there except for one??
What is the AUX SHEILD GROUND????
1. Empty
2. Violet = Right Rear Positive (RR+)
3. Violet/Black = Right Rear Negative (RR-)
4. White/Black = Left Front Negative(LF-)
5. White = Left Front Positive (LF+)
6. Black/White = Aux Shield Ground
7. Empty
8. Empty
9. Empty
10. Empty
11. Empty
12. Empty
13. Orange = Illumination/Dimmer
14. Blue = Power Antenna
15. Red = 12 Volt Ignition/Switched (12V+)
16. Yellow = 12 Volt Battery/Constant (12V+)
17. Black = Chassis Ground (12V-)
18. Gray = Right Front Positive (RF+)
19. Gray/Black = Right Front Negative (RF-)
20. Green/Black = Left Rear Negative (LR-)
21. Green = Left Rear Positive (LR+)
22. Empty
23. Empty
24. Empty
25. Empty
26. Empty
27. Empty
28. Empty
29. Empty
30. Blue/White = Amp Turn On
31. Empty
32. Empty
and my other question is how do u put the pins back into the harness cause i accidently pulled one out, do i just use some pliers to stick it back in there
1. Empty
7. Empty
8. Empty
9. Empty
10. Empty
11. Empty
12. Empty
22. Empty
23. Empty
24. Empty
25. Empty
26. Empty
27. Empty
28. Empty
29. Empty
31. Empty
32. Empty
