BUICK PARK AVE>current draw
this was one of my first setup in a buick century:
my amp was fused at 80 and i had a full ground. i found that buicks are hard to ground to the frame.
everything is ok until the bass hit ,then it drops hard
check all your connections.
it might be at the fuse, did you solder the ends of all the wires? thats helps to insure a good connection. are there any breaks in the power wire. (add-ons) a customer of mine had the same issue and the problem ended up being his power wire was short so he added so he added more wire. once i installed a solid piece of wire he had very little voltage drop. are your ground and positive wires the same size? cause they should be. hope that helps
jerryrobinson
jerryrobinson
chicago IL
mlstrass
