- Thread Starter
- #16
another question.The MRV-F345 is a flexible amplifier.
CH 1&2 crossover switch: Select high-pass, low-pass, or full-range operation for the CH 1&2 speaker outputs
CH 1&2 frequency control: Rotary control adjusts the crossover frequency from 30Hz-400Hz or 600Hz-8kHz (depending on frequency multiplication switch)
CH 1&2 frequency multiplication switch: Select "x1" for frequency band 30Hz-400Hz or "x20" for frequency band of 600Hz-8kHz
CH 3&4 crossover switch: Select high-pass, low-pass, or full-range operation for the CH 3&4 speaker outputs
CH 3&4 frequency control: Rotary control adjusts the crossover frequency from 30Hz-400Hz or 600Hz-8kHz (depending on frequency multiplication switch)
CH 3&4 frequency multiplication switch: Select "x1" for frequency band 30Hz-400Hz or "x20" for frequency band of 600Hz-8kHz
Input channel selector switch: Select between 1/2, 3/4, and 1+3/2+4
That means you can use the amp LPF set around 2kHz-4kHz depending on the woofer's off-axis performance and low frequency performance of the tweeters.
Since the amp doesn't feature a bandpass crossover feature, you will need some sort of high-pass filter on the woofers. what frequency depends on what other woofers are in the system. luckily, you can easily adjust the crossover frequency between woofers and tweeters as needed once you pick your tweeters. no passive crossovers are needed, but a single small non-polarized capacitor in series with each tweeter will offer extra protection if you accidentally change the frequency multiplier.
Ive been consistently stumbling across the terms 2nd, 3rd and 4th order crossovers
do I need to concern myself with this aspect of component systems?
e/
referring to the application i am building that is
