budget amp for 2 HDS312 at 4ohm
Im a bit confused. You have two dual 4 ohm subs and you want to run them at 4 ohms? If that is the case, then there's no budget amp in the world that would be cheap enough to do that for two of them. Now if you run them at 1 ohm, then that opens up the list of amps a bit
what are some good kinds to look out for? i seen a couple people saying the precision power amps are decent for budget but im just not sure
those ppi only put out if you wire low like .5 ohms then you will get 2000 clamped out of them. Go on facebook and join soundqubed only, they have a lot of Q2200.1 amps for 300 shipped.
BillyBrightEy3s
BillyBrightEy3s
peoria il
disturbed471985
