Brutus ?
JMOCK
hey ive finally made my decision im getting 2 12" kicker L7's and im putting them in a vented box. the subs are 2ohm DVC their 1500 watts max power 750watt RMS i was wondering what kind of amp to get, right now i got my eye set on the hifonics Brutus 1500d which is a 1500watt mono amp.
Just so you are aware, the Hifonics amp does 1500 watts at one ohm. If you are getting the 2 dual 2 ohm subs, you cannot run them at one ohm. If you want to run the Hifonics, you need to get the dual 4 ohm voice coil subs, or you need to get an amp that puts out more power at 2 ohms.
Has anyone had any luck with running it @ .75 ohms? Is it capabile of running that low without clipping? Has anyone had them bench tested @ 3 ohms? I am wondering if this amp would handle the 13w7 or not?
JMOCK
JMOCK
Auburn, ME
limitkid7
Doxquzme
    May 14, 2026
ThxOne
    May 13, 2026
