bridged amps, went into protect
power acoustik ov1-4000d...they are meant to be linked...its not that...i just cant figure out what i did wrong...all subs were in parallel and both amps were connected to one + and one - that split to all of the subs...there was only 1 + and 1 - going into the box
Thats because you are running a 1 ohm signal into a staped amp. Since you have the amp straped and both subs in parallel, you will see 1ohm at the subs but the amp are seeing .5ohm and thats why it is in pretect.
i have unhooked all of the wires except power, ground and turn on wire and it is still in protect...fixable?
Bender.
The Original Offender
Bender.
tennessee
Bender.
