Xprime4
****in' canadian
I'm about to buy new speakers for my front stage. Was thinking boston acoustic pro60's. Their impedance is 3ohm dual coil. what the hell does that mean? dual coil like subs? 1.5 or 6ohm at the amp?
Anyway, i'll be using an mb quart pa4100 amp.
http://www.sonicelectronix.com/item_9860_MB+Quart+Premium+PAB+4100.html
The amp is stable at 2ohm. Right now, it's bridged so i got 2x300watt rms
I'm using that to power entry cdt comp with tw25 tweeters with another crossover (the other want didn't like that much power) , but they get smelly sometime only after one minute at full tilt. Anyway, i'm looking for new comp.
Once it's bridged, the amp does get hotter than at 4x100watt rms. Specs says it's stable at 4ohm bridged, but will it work at 3ohm or whatever those speakers are?
Any other suggestion for high powered speaker along those lines? SQ is a must too!!! And how will the amp react at 3ohm? since it's stable at 2ohm unbridge i assume it could handle 3ohm bridged?
