BP design request, have $ ready to PP now
  • 5
kmanian
Grand Cayman
Sub: 1 Phoenix Gold Ti210d4
Input power: 750w
Size Constraints: 32"w X 15"t X 20"d (bottom) 16" (top)*the dept is a measurement I want to keep if possible.
Additional requirements: 4th or 6th order is fine, useable freq below 35 hz to above 80hz. Solid bass reinforcement is key, fairly flat between 40 and 70hz. The box will be located in the trunk of an M5 with the port(s) entering the cabin through the rear deck which is at approximately 20" from the trunk floor.
Specs can be found on this link http://www.phoenixgold.com/images/pd...fer_manual.pdf
I will PP $ for a complete design including cut sheets. No offence, but if you don't consider yourself a enclosure design guru, please save both of us some time.
Tried to, but not reply.
To clarify, I have been out of town for a few days, but I did get back to you a few hours ago. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
I am to busy right now to get something to you as quick as your wanting, but I'm sure GM can whip something up for you.
Yep, he did. NP here and I have found someone to do it so thanks.
657
973
There are bluetooth amplifiers. You can just use your phone or an I Pod as the music source and not touch the radio.
I've used that driver and the ported box is closer to about 2 cubes. We did 1 in a stuffed/sealed 1-1.25 cubic foot box, stuffed with 1 lb of...
830
kmanian
kmanian
Grand Cayman
kmanian
maylar
    Jun 2, 2024
    Jun 1, 2024
