box sealing
pj_chevy03
please ban me
928
Alabama
o.k 3 simple questions about box building
1. what is the best type of liquid nails to use to hold box together
2. what are the best size/thread screws to use
3. what is the best type of caulk to use to seal the box's edges in the inside of the box
o.k 3 simple questions about box building1. what is the best type of liquid nails to use to hold box together
1. Carpenters/wood glue. Cheaper, works fine. Glue joint is stronger than the wood itself.
2. Coarse threaded drywall screws seem to be the screw of choice. Length will depend on the size of the wood you're using ... probably around 1 1/2 or a little larger.
3. White **** that comes in a tube is fine. Can't think of a brand off the top of my head ... maybe GE or something. Doesn't really matter. Fiberglass resin will also work.
- Steve
i perfer titebond woodglue as well....over anything
as far as fumes go.....if you let your box dry for a day or two(like it should to have the glue and chauk set correctly)...the fumes are no longer there....but i'm not sure if they themselves would harm a sub anyways
I've heard they had the possibility of messing up a certain type of surround.
Be careful with anything that smells I guess ... as mentioned above, let it air out.
- Steve
- Steve
well i totally agree w/ the second part there :thumbsup
and i've never heard of it messed w/ surronds....something to look out for
I thought I was warned with my old boob-cone SE's, but that was quite a while ago ... so I forget :p
- Steve
do those use the same surround as anything they have made since then....if it is.....then i could have trouble w/ every series from RE since then //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
Not sure.
People have been sealing the inside of their boxes with caulking for a long time and I've only seen a couple people with messed up surrounds. Should be fine.
- Steve
use elmer wood gule to assemble the then use white lightning to seat the box. I work for a wood butcher (he knows all about wood) and if u are really anal about ur box i could ask him.
there are specific brands that recommend not using 'caulk or similar sealing agents' other then wood glue unless the stuff is given time to cure. (only like 24 hours). I know Visonik does and i believe MTX used to mention it ( a few years ago). Same with spray glue for carpeting. so its really no biggie. Most of us usually have the box ready before we get the driver anyhow...
Start by laying the larger bottom panel in an open space, then slowly “dry” assemble it by laying the pieces where they go like a puzzle. It...
These are also very good drivers, some of the best bang for the busk on shallow mounts. DD Audio SL610-D2 10"...
5
158
The it to a custom air brush guy and tell him what you want. You can always stain, plexiglass windows, and put led lights inside the box. Search...
6
509
Thanks man! Quitting drinking and battling DRESS syndrome has given me a new outlook on life.
8
813
i have a 15 already for the lows ita a little over kill for a crew cab but I like it and I was hoping it would sound better and louder than my old...
7
642
pj_chevy03
please ban me
pj_chevy03
Alabama
helotaxi
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
