box recomendations for sq with my hybrid
CJW
PA
12" TC9 with Re soft parts dual 2 ohm, MT cone and cap
specs are:
Re: 3.6 Ohms
Fs: 31.2
Le: 3.5 mH
Qms: 4.75
Qes: .45
Qts: .43
Cms: 121.59
Mms: 228 g
Vas: 39.71
Sd: 480 cm^2
Bl: 18.35
Spl: 85.96 dB
Xmax: 27mm
Id like to stay sealed to keep weight down if at all possible.
Any help is very appreciated. I listen to just about everything as well.
Thanks
Ok so I just looked into subs with the same motor. The rl-p recommends 1.5-2 cuft ported and so does the tc9.
Ive got about 2.5 cu ft that I can use for the box. I already know how I want to build the box I just need to know what internal volume I should go for.
I probably will end up with 2 cube ported. Simply because I have nothing else telling me other wise.
If 2 cubes is all I need for ported I may as well port it
What tuning should I use for daily driving. I was thinking around 30 or so.
I had an re8 in a .75 cube at 32hz on about 250-300rms and it sounded good for what I was playing it for. I am adding an amp to my incars and the 8 just wont be enough. Hence the new sub
CJW
CJW
PA
MikeyB
