M msu_gangsta 10+ year member Junior Member 11 0 Lansing, Mi May 6, 2002 #1 does filling your box with polyfil really give u a better sound, what exactlly does it do? Click to read more...
maylar 10+ year member Electrical Weenie 3,520 8 Connecticut May 6, 2002 #2 It makes the box behave as though it was bigger, which usually lowers the frequency the sub will play and flattens out the response curve. Recommended for any box under 5 cu ft.
D derekls 10+ year member Member 55 0 jamestown, Tn May 6, 2002 #3 it slows the sound waves in the box down ......... and Yes it can make your sub sound better if your box is to little
G GiddoT 10+ year member Junior Member 29 0 Orlanod Fl May 7, 2002 #4 since I have the subs in a small box so that I can acually have atrunk to put **** in the subs are in a smller box then they should be in so I put the R14 pink panther insulation and the **** hit hard as hell for thart small of a box it helps a lot the car just shakes o i hope that help you out peace
