misfit138
a whole new type of aids
First of all, I wouldn't recommend using 10 gauge for power & ground wire. Secondly, the amplifier is suspect at best. It's 800 watt rating is most likely an outlandish MAX power claim. Most of the time an amplifier's rms rating is roughly half of it's MAX rating, and then there's the matter of your ohm load. The amplifier might do 400 watts rms @ 2 ohms and 200 or less watts rms @ 4 ohms. Then there's the enclosure itself. A Kicker Comp shouldn't be causing any half decent enclosure to vibrate or flex in the slightest. If the enclosure is flexing AT ALL there's something obviously wrong.
And now I'm going to be brutally honest. The Kicker Comp is weak. It's not going to perform extremely well if you're interested in authoritative bass. Maybe you should think about stepping up to a Kicker CVR or Alpine Type R. You should also tell us the model number of your amp so we can look up it's specs...
